The firmware update Ver.4.20 from Ver.4.10 incorporates the following issues:
Display of IP ADDRESS in Setup Menus > CONNECTION SETTING > INFORMATION is added.
Improvement of shutter speed setting for TTL slow sync flash shooting
In P and A mode, this firmware makes the slowest shutter speed slower than 1/8 sec. for the shooting used in a scene where relatively long exposure is required (ex. a flash shooting with night view background). In case the shutter speed setting is AUTO, the shutter speed becomes max. 4 sec in P mode and max. 30 sec. in A mode.
Fix of minor bugs.
Fujifilm GFX50R firmware 2.20
The firmware update Ver.2.20 from Ver.2.10 incorporates the following issues:
Fix of minor bugs.
The firmware update Ver.4.30 from Ver.4.20 incorporates the following issues:
GF35-70㎜F4.5-5.6 WR availability
•[AUTO+MANUAL], [AUTO] and [MANUAL] selection will be available at [APERTURE SETTING] in [BUTTON/DIAL SETTING] menu under the [SET UP MENU], so that you can adjust the aperture with the command dial in case that no aperture ring lens, GF35-70㎜F4.5-5.6 WR is mounted.
Note-1:[APERTURE SETTING] button will be added with new firmware, and it will be activated
in case that the above lens is mounted (It will be gray out without the above lens).
•“ROTATE THE ZOOM RING TO EXTEND THE LENS” message will appear before photo taking for the customer to avoid miss-shooting since GF35-70㎜F4.5-5.6 WR is retractable.
The bug has been fixed that an image cannot be played back with a specified file name created by the [EDIT FILE NAME] function.
The firmware update Ver.2.30 from Ver.2.20 incorporates the following issues:
The following specification has been revised to improve compatibility with SDXC memory card format.
The maximum number of frames that can be recorded in a single folder has been changed from 9,999 to 999.
If you are using a macOS computer to process recorded files in the SDXC memory card, make sure to follow the procedure below before upgrading the firmware. Follow the instructions in “II-2. If using an SDXC memory card with existing files or one that has not been recently formatted:” in the article titled “Important notice for consumers processing FUJIFILM digital camera files using macOS” that was published on Feb. 2 in this web site and then format the SDXC memory card before using it.
One major bug has been fixed that the area visible on the main display in the dual display mode shows narrower angle of view than the actual image being captured when “35mm FORMAT MODE” was on at the manual focus setting.
