The firmware update Ver.3.00 from Ver.2.01 incorporates the following issues:
1.Pixel Shift Multi-Shot function is added.
In the Pixel Shift Multi-Shot mode, the camera takes a series of 16 RAW images and by using in-body image stabilization(IBIS), moves the image sensor to get a high-resolution and real color* image. The multiple images are then combined to create a Digital Negative (DNG) RAW file using the FUJIFILM Pixel Shift Combiner software.
real color : As a pixel of an image sensor has one color filter from red, green or blue, we cannot detect the real color for the pixel. We need to interpolate the other colors from the surrounding pixel data for that pixel. This is called the demosaicing process. In case of Pixel Shift Multi-Shot photography, we can receive red, green and blue data for every pixel position. This means we receive real color information when using Pixel Shift Multi-Shot mode and the demosaicing process is not necessary.
Ratings to images recorded in the [Jpeg + RAW] mode are applied to both Jpeg and RAW files.
The phenomenon is fixed that in a multiple-flash shooting where the EF-X500 is used as a commander, flashes in some groups sometimes don’t fire correctly. Also in case the EF-X500 is used as a commander and the EF-60 as a remote flash, upgrade the camera firmware to the latest version.
Accuracy of the Eye AF function for the front eye is improved
The firmware update Ver.3.02 from Ver.3.01 incorporates the following issue:
The phenomenon is fixed that in rare cases, linear noises can be recorded in the longitudinal direction when shooting a scene with large highlighted area.
TOKYO, April 22, 2021 – FUJIFILM Corporation (President: Kenji Sukeno) is pleased to release the latest firmware update for the “FUJIFILM GFX100” (GFX100) in [b]June 2021[/b]
Improved autofocus performance to the same level as “GFX100S”
The new firmware updates the camera’s autofocus algorithm to the latest version to boost AF speed and Face/Eye-detection performance, enhancing AF accuracy even in portrait photography that involves subject movements. The ability to track a moving subject will also be improved, making it possible to maintain an accurate focus on a subject that is moving away from the camera.
Coordinated control of in-body and optical image stabilization mechanisms
The new firmware enables coordinated control of the camera’s in-body image stabilization (IBIS) and a lens’s optical image stabilization (OIS). Image stabilization is applied with optimum correction based on the two mechanisms’ acceleration, frequency detected by gyro sensors and the amount of camera shakes to minimize motion blur even when shooting handheld. This enhances the image stabilization function of GF lenses featuring OIS such as FUJINON Lens GF120mmF4 R LM OIS WR Macro or the FUJINON Lens GF45-100mmF4 R LM OIS WR with additional 0.5-stop.
Addition of the Film Simulation “Nostalgic Neg.”
The new firmware adds the Film Simulation “Nostalgic Neg.,” characterized by colors and tones reminiscent of the “America New Color,” which emerged in the 1970s to advocate the potential of color expressions to the world and established color photography as the mainstream style for photographic fine arts. The style combines “soft tonality” with “high saturation” at the same time and applies warm amber to highlights to soften the look while maintaining fine details and pop colors in shadows for lyrical looks.
Other added functions and operational improvements
The level of “clarity” can be set in the range from -5 to +5.
The “tone curve” can be adjusted in the increment of 0.5 stop for both highlights and shadows.
The “focus limiter” function is added to specify any focusing range. Choose the default focusing distance or select it from the specified range.
Pictures can be enlarged in the magnification of 1x, 2x, 4x or 8x in playback. There is also an option to select the magnification used in the previous playback (from center).
Function button can be assigned to switch “shooting mode” between P, S, A and M modes.
The front and rear command dials can be set to rotate in a reverse direction.
The number of items in the Q menu can be selected from 4, 8, 12 or 16 for both stills and video. The items to display in the Q menu are customizable.
The Q button can be assigned as a function button.
The camera stays ON even when an SD card is removed.
Electronic image stabilization is available while shooting video.
It corrects camera shake that occurs when shooting video handheld. (1.1x crop when this mode is turned on)
Live View can be enlarged even while shooting video.
The Focus Check Lock can now also be set to ON/OFF to maintain focus check or not when starting to shoot video.
Video recorded in the SD card can be backed up to the SD card in another card slot.
The elapsed video recording time can be displayed on the LCD for checking.
The AF area size can be changed while shooting video.
Video files recorded with F-log can be played back in conversion equivalent to BT.709.
Added White Balance / ISO metadata to RAW footage, output to Atomos Ninja V HDR Monitor Recorder via HDMI. The footage is recorded as Apple ProRes RAW files and White Balance / ISO can be adjusted in Final Cut Pro.
5. Precautions
In firmware Ver.4.00, the menu structure has been changed and some functions have been renamed. Particularly, the movie setting menu has undergone major changes due to the expansion of setting items, and some of the settings will revert back to the default value accordingly.
This new firmware can be downloaded via the smartphone App “FUJIFILM Camera Remote”. However, since many items have been changed, please be sure to check the detailed information about this firmware on the official website before implementing the update.
he firmware update Ver.4.10 from Ver.4.00 incorporates the following issues:
Regarding the details, download the “GFX100 New Features Guide[Ver.4.10]” from our website:
GFX100 will be able to output the RAW video data to Blackmagic Design’s Video Assist 7” 12G HDR and Video Assist 5” 12G HDR as “Blackmagic RAW” through HDMI up to 4K/29.97P 12bit (see Note-2 below)
•New firmware with this feature is supposed to be released by Blackmagic Design.
•RAW video data gives maximum flexibility for exposure adjustment and color grading in post-production for professional videographers.
Besides, simultaneous output of RAW with Film Simulation / F-Log / Hybrid Log Gamma (HLG) to SD card in the camera is also available.
Note-1:GFX100/100S records “Blackmagic RAW” only with Blackmagic Design’s Video Assist 7”12G HDR and Video Assist 5” 12G HDR (as of Oct. 7, 2021).
Note-2:This video RAW data is compatible with 4K (3840×2160) 29.97P/25P/24P/23.98P(Not compatible with FHD).
GFX100 has been modified to comply with energy conservation regulations in the United States and Canada.
・The maximum number of frames that can be stored in a single folder will be changed from 9,999 to 999 with Ver.4.20 or later.
The firmware bugs have been fixed, which caused a EVF display failure when the “FRAME RATE PRIORITY” was selected in the [BOOST] menu by operating through the following menu flow.
