Fujifilm GFX100S: atualização de firmware
firmware v1.10
30/06/2021
Addition of White Balance and ISO metadata to RAW footage
Added White Balance / ISO metadata to RAW footage, output to Atomos Ninja V HDR Monitor Recorder via HDMI. The footage is recorded as Apple ProRes RAW files and White Balance / ISO can be adjusted in Final Cut Pro.
Improvement of Custom mode function
Changes to the functioning of custom modes have altered how custom settings banks are created and edited using IMAGE QUALITY SETTING >DIT/SAVE CUSTOM SETTING and MOVIE SETTING > EDIT/SAVE CUSTOM SETTING in the shooting menu. You can register/edit after selecting the custom number from C1 Through C6.
The phenomenon is fixed that an image cannot be played back with a specified file name created by the EDIT FILE NAME function.
Fix of minor bugs.
Download do FW e do guia com os novos recursos:
Firmware 1.20
07/10/2021
The firmware update Ver.1.20 from Ver.1.10 incorporates the following issues:
Regarding the details, download the “GFX100S New Features Guide[Ver.1.20]” from our website.
- GFX100S will be able to output the RAW video data to Blackmagic Design’s Video Assist 7” 12G HDR and Video Assist 5” 12G HDR as “Blackmagic RAW” through HDMI up to 4K/29.97P 12bit (see Note-2 below)
•New firmware with this feature is supposed to be released by Blackmagic Design.
•RAW video data gives maximum flexibility for exposure adjustment and color grading in post-production for professional videographers.
Besides, simultaneous output of RAW with Film Simulation / F-Log / Hybrid Log Gamma (HLG) to SD card in the camera is also available.
Note-1:GFX100/100S records “Blackmagic RAW” only with Blackmagic Design’s Video Assist 7”12G HDR and Video Assist 5” 12G HDR (as of Oct. 7, 2021).
Note-2:This video RAW data is compatible with 4K (3840×2160) 29.97P/25P/24P/23.98P(Not compatible with FHD).
Minor bugs have been fixed.
Firmware 1.30
16/02/2022
・The maximum number of frames that can be stored in a single folder will be changed from 9,999 to 999 with Ver.1.30 or later.
Firmware 1.31
30/03/2022
Revised specification from Ver.1.30 to Ver.1.31
The firmware bugs have been fixed, which caused a EVF display failure when the “FRAME RATE PRIORITY” was selected in the [BOOST] menu by operating through the following menu flow.
[POWER MANAGEMENT] ➔ [PERFORMANCE] ➔ [BOOST]
