Fujifilm X-H2S: atualização de Firmware
Firmware 1.01
07/07/2022
Revised specification from Ver.1.00 to Ver.1.01
The firmware bug has been fixed, which caused the firmware hung-up when the following three conditions coincide.
•“ON” or “ON HDMI ONLY” is selected at the “HIGH SPEED REC” menu.
•”360Mbps” or “720Mbps” is selected in the “MEDIA REC SETTING” menu.
•”Blackmagic” or “ATMOS” is selected in the “RAW OUTPUT SETTING” menu.
The firmware bug has been fixed, which caused that the shutter remains closed after taking a picture when using the “E-FRONT CURTAIN SHUTTER” with the slow shutter speed more than 2 minutes.
A Fujifilm disponibilizou a versão 1.02 do firmware da X-H2S:
[i]
Revised specification from Ver.1.01 to Ver.1.02
The firmware bug has been fixed, which caused that the amount of change in focus zoom was smaller than the spec when the FOCUS AREA was moved up and down in the vertical direction with the LCD in magnified view through the following operation.・[Movie Mode] ➔ [MANUAL FOCUS]
Depending on the macOS version or Mac computer itself, “Web Camera” function will not work using the USB connection between Mac and X-H2S.
USB ID used for the connection with external devices, such as Drone, Gimbal, etc. has been corrected.
4)Other minor bugs have been fixed.[/i]
Download em: FUJIFILM X-H2S | Firmware | FUJIFILM X Series & GFX – Global
Fonte: Fujifilm X-H2S Firmware 1.02 Released - Fuji Rumors
Firmware 2.00
29/09/2022
- File Transfer (FT-XH) feature has been available.
When “FT-XH” is attached, the following feature is available.
Image transfer and tethered photography with Wired / Wireless LAN.
Posting the image data on to the FTP server with Wired / Wireless LAN or using USB tethering feature of the smart phone.
Operating the multiple cameras (up to 4 cameras) through the browser in the PC, smart phone, or tablet to shoot the movie with “FT-XH”.
- AF feature has been enhanced.
“FOCUS METER” function has been added in “MF ASSIST” in the “PHOTO SHOOTING” menu for still photo.
The bug has been fixed, which caused that the focal point of a lens was sometimes behind the subject when shooting the small object by selecting “SUBJECT DETECTION SETTING”.
The bug has been fixed, which caused that camera sometimes stopped shooting when shutter button was half-pressed and hold after “BURST” mode is used with the specific settings.
The bug has been fixed, which caused that the flash did not synchronize with the electronic shutter sometimes at “High Speed Sync” mode or that the black shadow ghost phenomenon appeared in the photo sometimes depending on the shutter speed.
The bug has been fixed, which caused that the pre-view image got frozen for a few seconds when using the XF18-120mmF4 LM PZ WR lens and half-pressing the shutter button at “Stand-by” for the movie taking.
Firmware 2.10
27/10/2022
Revised specification from Ver.2.00 to Ver.2.10
Using “File Transfer” (FT-XH), the network tether shooting functions of “FUJIFILM Tether Shooting Plug-in/Plug-in PRO (Adobe Lightroom Classic)” and “Capture One” will be available (See notes below).Note-1: The following versions of “FUJIFILM Tether Shooting Plug-in/Plug-in PRO” will be required for the network tether shooting functions will be required. We will make an announcement as soon as they are released.
・FUJIFILM Tether Shooting Plug-in/Plug-in PRO (Win) Ver.1.26
・FUJIFILM Tether Shooting Plug-in/Plug-in PRO (Mac) Ver.1.26Note-2: Versions of “Capture One” that will be required for the network tether shooting functions is to be decided. We will also make an announcement as soon as they are released.
The firmware bug has been fixed, which caused that the “Remote Rec Function” was shut off while using the FT-XH.
Another minor bug has been fixed.
