Testes na prática
Enviado de meu SM-A715F usando o Tapatalk
Muito legal da parte da Fuji de ter feito isso. Imagina se a Canon solta firmware para atualizar o Dual Pixel da R e RP para os mesmos nívels ou similares da R5 e R6?
Será que o fato de serem processadores diferentes entre X-T3 e X-T4 vai ter alguma perda ou diferença na prática mesmo após esse firmware?
Não são diferentes, o conjunto é igual sensor e processador.
Eu passo… já tive minha experiência com a Fuji.
Serio muito legal mesmo Thales, mas, a R5 e R6 tem um novo modelo de dual pixel AF: Dual Pixel CMOS AF II .
Após alguns testes só posso dizer que o que era bom ficou melhor ainda!
Chegou a testar com vídeo?
Fujifilm X-T3 firmware 4.10
The firmware update Ver.4.10 from Ver.4.00/4.01 incorporates the following issues:
Display of IP ADDRESS in Setup Menus > CONNECTION SETTING > INFORMATION is added.
Improvement of shutter speed setting for TTL slow sync flash shooting
In P and A mode, this firmware makes the slowest shutter speed slower than 1/8 sec. for the shooting used in a scene where relatively long exposure is required (ex. a flash shooting with night view background). In case the shutter speed setting is AUTO, the shutter speed becomes max. 4 sec in P mode and max. 30 sec. in A mode.
Fix of minor bugs.
Versão 4.11
Data: 29/06/2021
The firmware update Ver.4.11 from Ver.4.10 incorporates the following issues:
When using the Shoe mount flash EF-X8, the display of the FLASH SETTING is changed from “SUPPLIED FLASH” to “EF-X8”.
The phenomenon is fixed that an image cannot be played back with a specified file name created by the EDIT FILE NAME function.
Fix of minor bugs.
Download:
Firmware 4.12
07/20/2021
The firmware update Ver.4.12 from Ver.4.11 incorporates the following issues:
Minor bugs have been fixed.
Firmware 4.20
16/02/2022
・The maximum number of frames that can be stored in a single folder will be changed from 9,999 to 999 with Ver.4.20 or later.
Firmware 4.30
29/06/2022
Revised specification from Ver.4.20 to Ver.4.30FUJINON lens, XF150-600mmF5.6-8 R LM OIS WR has been available.
The accuracy of AF function has been improved at manual focus mode using “One-Push AF”.
Other minor bugs have been fixed.
Firmware 4.40
29/09/2022
Novo guia de funcionamento devido as novas funções de controle para zoom e foco que foram adicionadas/modificadas.
Verifique link acima para descrição completa.
Exposure adjustment function for the pre-view image/movie has been enhanced by optimizing the parameters for the exposure control when XF150-600mm is used.
“AF+MF” function has been available even at movie taking.
