Nikon Z5: atualização de firmware
Nikon Z5 firmware v1.10
https://downloadcenter.nikonimglib.com/en/download/fw/401.html
• A Save focus position option has been added to the SETUP MENU. If On is selected, the focus position in effect when the camera is turned off will be restored when the camera is next turned on. This option applies only when the camera is used with Z mount autofocus lenses.
• Improved low-light autofocus detection times for Custom Setting a11 (Low-light AF).
Nada do aumento fps, seria bom de mais para ser verdade.
A galera da astrofoto agradece!
Que burro! Dá zero pra mim!
Sério agora: vi que se trata do ponto de foco, não do foco em si. Minha câmera, mesmo usando lentes AF em foco manual, ao ligar e desligar a câmera, o foco muda. Pensei que fosse algo nesse sentido.
Nikon Z 5 firmware 1.11
Data: 13/07/2021
https://downloadcenter.nikonimglib.com/en/download/fw/415.html
Addressed an issue that would in rare circumstances result in unusually loud noises from the aperture mechanism when the zoom or focus rings on F mount lenses connected via an FTZ mount adapter were rotated.
Nikon Z5 firmware 1.20
10/11/2021
https://downloadcenter.nikonimglib.com/en/download/fw/430.html
• Added support for:
- FTZ II mount adapters, and
- NIKKOR Z 24-120mm f/4 S lenses.
• Improved face/eye detection performance and the visibility of subjects in pictures taken using an optional flash unit.
Nikon Z5 firmware 1.21
27/10/2022
https://downloadcenter.nikonimglib.com/en/download/fw/468.html
Fixed an issue that in rare circumstances resulted in vibration reduction failing to function after the firmware was upgraded to version 1.20.
