Nikon Z9 : atualização de firmware
Nikon Japão anunciou que a atualização de firmware 1.10 para a Z9 será disponibilizada na data de 05/01/2022.
Thank you for your continued patronage of Nikon products.
We are pleased to announce the release of firmware Ver.1.10 for the flagship mirrorless camera “Nikon Z 9” on January 5, 2022 at 15:00.
With the firmware Ver.1.10 for “Z 9”, the high-speed continuous shooting time is greatly improved. When shooting at approximately 20 frames per second with “RAW (high efficiency) + JPEG BASIC (size L)” split recording, it is possible to shoot from the conventional approximately 3 seconds to the world’s longest * 1 approximately 15 seconds * 2. It will be.
Shooting is possible when shooting at approximately 20 frames / sec with split recording of “RAW (high efficiency ★) + JPEG BASIC (size L)” or “JPEG FINE (size L) + JPEG BASIC (size S)”. The time will be reduced from the conventional 3 seconds to 8 seconds * 2.
By improving the high-speed continuous shooting time, it further supports high-pixel shooting at the decisive moment of a subject moving at high speed.
In addition, we plan to add various video functions and improve operability and functions when shooting still images and videos in future firmware updates.
As of December 28, 2021, this is a mirrorless camera equipped with an image sensor with 30 million or more effective pixels that has been released, and is used for high-speed continuous shooting at approximately 20 frames per second with “RAW + JPEG” split recording. According to Nikon research.
When using the attached lens “NIKKOR Z 50mm f / 1.8 S” and memory card “ProGrade Digital COBALT 1700R 325GB”. The continuous shooting time is reduced when “Slot 2 function” is set to “Backup recording” or when “Automatic distortion correction” is set to “ON”.
Firmware 1.10
05/01/2022
download:
https://downloadcenter.nikonimglib.com/en/download/fw/432.html
• Increased the burst length for dual-format (NEF/RAW + JPEG or JPEG + JPEG) pictures taken at 20 fps in continuous high-speed release mode.
“C” firmware version 1.00:
  • NEF/RAW (high-efficiency★) + JPEG basic (large): Approx. 3 seconds *
  • JPEG Slot 1 - JPEG Slot 2 (Slot 1: JPEG fine (large); Slot 2: JPEG basic (small)): Approx. 3 seconds *
    “C” firmware version 1.10:
  • NEF/RAW (high-efficiency★) + JPEG basic (large): Approx. 8 seconds *
  • JPEG Slot 1 - JPEG Slot 2 (Slot 1: JPEG fine (large); Slot 2: JPEG basic (small)): Approx. 8 seconds *
  • The length of the burst that can be taken before the frame advance rate drops. Figures are reference values obtained via in-house measurements performed using a NIKKOR Z 50mm f/1.8 S lens and a ProGrade Digital COBALT 1700R 325GB CFexpress memory card. Burst length will drop in some circumstances, including if:
  • Backup is selected for Role played by card in Slot 2 or
  • ON is selected for Auto distortion control.
    • Options highlighted in the Filtered playback criteria list in the PLAYBACK MENU can now also be selected and deselected by pressing the multi selector right.
    • Fixed an issue that prevented optional SB-5000 flash units synchronizing with the shutter when all the following conditions were met:
  • A shutter speed faster than the flash sync speed was selected with 1/200 s (Auto FP) or 1/250 s (Auto FP) chosen for Custom Setting e1 Flash sync speed in the CUSTOM SETTINGS MENU.
  • The SB-5000 was controlled via radio AWL using an optional WR-R10 or WR-R11a wireless remote controller mounted on the camera.
  • The flash unit was not mounted on the camera accessory shoe.
Nikon, silenciosamente, atualiza o log de atualizações de firmware da Z9, Z7 II e Zfc
Nikon quietly updated the changelog (release notes) for the last few Z camera firmware updates:
Original Nikon Z9 firmware v1.11 | Updated Nikon Z9 firmware v1.11
Original Nikon Z7 II firmware v1.31 | Updated Nikon Z7II firmware v1.31
Original Nikon Z fc firmware v1.20 | Updated Nikon Z fc firmware v1.20
The Z9 firmware update has several new lines added, while the other two updates just “gained” support for the new Nikkor Z 400mm f/2.8 TC VR S mirrorless lens.
From a software development point of view, it is a bad idea to add functionality to an already officially released version.
Needless to say that users will not have a clue that the release notes were updated… Just a bad practice from Nikon and I hope they will not do it again. I do not know how far back they went to update the release notes, but the Z6II camera still doesn’t have support for the new 400mm Z lens. Maybe we will finally see the long-rumored Z6II/Z7II firmware updates being officially announced next week at the 2022 CP+ show. Stay tuned!
fonte:
Saiu uma enorme atualização de firmware para a z9.
:snack:
Interessante, muitas coisas para uma atualização de firmware.
Nikon muito agressiva. Estou gostando…
Mandando ver! Nada como competição pra tirar a bunda da cadeira dessa galera. Canon e Nikon tentando recuperar o que perderam pra Sony.
Saiu uma nova avaliacao no dpreview sobre foto e video. :snack:
Estou impressionado com a rapidez que a Nikon tem atendido ao feedback dos usuários.
:clap: :clap: :clap: :clap: :clap:
Sim, acredito que o profissional que precisa de uma z9 está bem satisfeito, a z7 z 6ll e a z 30 parecem atender bem os usuários.
Ainda bem, pois tempos atrás era justamente o contrário. :smiley:
Para deixar no padrão. :smiley:
Firmware 2.10
06/07/2022
https://downloadcenter.nikonimglib.com/en/download/fw/454.html
Time Required to Complete This Update
This update takes approximately 6 minutes. A progress bar will be displayed when the update begins but it takes about 2 minutes for the progress bar to be displayed. Do not turn off the camera until the firmware update is complete.
Firmware 2.11
30/08/2022
https://downloadcenter.nikonimglib.com/en/download/fw/460.html
Fixed an issue that in very rare circumstances would cause the camera to stop responding.
Firmware 3.00
26/20/2022
Download e informações sobre a atualização:
https://downloadcenter.nikonimglib.com/en/download/fw/467.html
Tem algumas atualizações interessantes para vídeo. Mais informação no link abaixo.
Firmware 3.00
Nikon Z 9: Hi-Res Zoom Speed Comparison
Nikon Z 9: Hi-Res Zoom with firmware version 3.00
