COLORMUNKI SMILE
De acordo com a Xrite:
**ColorMunki Smile – Discontinued Mac Support Mac OS X 10.15 Catalina was released on October 7, 2019. This new Mac operating system requires applications to be 64-bit compliant.ColorMunki Smile software is a 32-bit application, and will not run on Mac OS X 10.15 Catalina.
There are no plans to develop a 64-bit application for ColorMunki Smile.
To continue to use the ColorMunki Smile on a Mac, you will need to avoid upgrading to Mac OS X 10.15 Catalina.
If you decide to upgrade to Mac OS X 10.15 Catalina, you should consider upgrading to the i1Display Studio or i1Display Pro which are both 64 bit compliant.
Para quem ter esse colorímetro noa atualize para o OS X Catalina, pois não haverá mais suporte.
Caso o faça, vai ter de troca de calibrador.
