Nikon Z50: atualização de firmware
Firmware v2.03
https://downloadcenter.nikonimglib.com/en/download/fw/392.html
Pressing the playback zoom in button to display a preview would cancel changes to Set Picture Control > Hue made using NEF (RAW) processing in the RETOUCH MENU.
Certain aperture values would not be selected when control rings for the following lenses were rotated to stop aperture down in movie mode:
NIKKOR Z 50mm f/1.2 S
NIKKOR Z 24-50mm f/4-6.3
NIKKOR Z 24-200mm f/4-6.3 VR
NIKKOR Z DX 16-50mm f/3.5-6.3 VR
NIKKOR Z DX 50-250mm f/4.5-6.3 VR
Tinha esperanças de que eles fizessem update no sistema de foco da Z50 para ficar mais próximo da Z6II e z7II.
Também penso isso na Z6 e Z7, Sony A9 foi longe com as atualizações :ponder:
Pessoal do software da Nikon tem que comer muito arroz com feijão ainda! :hysterical:
Z50 firmware v2.10
https://downloadcenter.nikonimglib.com/en/download/fw/402.html
• A Save focus position option has been added to the SETUP MENU. If On is selected, the focus position in effect when the camera is turned off will be restored when the camera is next turned on. This option applies only when the camera is used with Z mount autofocus lenses.
• Fixed an issue that resulted in the option selected for Custom Setting a2 (Auto-area AF face/eye detection) in P, S, A, and M modes being reset whenever Custom Settings for mode U1 or U2 were reset.
Eu vi hoje cedo e achei pífio… esperava muito mais.
Firmware v2.11
Data: 24/06/2021
Fixed an issue occurring after the camera firmware was updated to version 2.10 that sometimes amplified the sounds generated by the aperture mechanisms when zoom or focus rings were rotated on certain F mount lenses connected via an FTZ mount adapter.
Download:
https://downloadcenter.nikonimglib.com/en/download/fw/409.html
Nikon Z 50 firmware 2.20
10/11/2021
https://downloadcenter.nikonimglib.com/en/download/fw/429.html
• Added support for:
  • FTZ II mount adapters, and
  • NIKKOR Z 24-120mm f/4 S lenses.
    • Improved face/eye detection performance and the visibility of subjects in pictures taken using an optional flash unit.
Nikon Z 50 firmware 2.30
20/10/2022
https://downloadcenter.nikonimglib.com/en/download/fw/462.html
• [Save focus position] and [Recall focus position] have been added to the roles that can be assigned using Custom Setting f2 [Custom controls (shooting)] in the [CUSTOM SETTING MENU]. As of October 20, 2022, these options were supported with the following lenses:
  • NIKKOR Z 70-200mm f/2.8 VR S
  • NIKKOR Z 100-400mm f/4.5-5.6 VR S
  • NIKKOR Z 400mm f/2.8 TC VR S
  • NIKKOR Z 400mm f/4.5 VR S
  • NIKKOR Z 800mm f/6.3 VR S
    • The behavior of autofocus during memory recall has been improved to ensure that the focus position will not change in any focus mode even if the shutter-release button is pressed halfway while focus recall is in progress.
    • During remote photography with the ML-L7, the camera will now focus with every shot taken with [AF-C] selected for [Focus mode] if [Release] is chosen for Custom Setting a1 [AF-C priority selection] in the [CUSTOM SETTING MENU].
    • Fixed an issue that sometimes resulted in the settings selected for Custom Setting f2 [Custom controls (shooting)] in the [CUSTOM SETTING MENU] not performing as expected in user settings modes.
