“Silent mode” is now respected when opening Sharpen from a host app
This means it won’t require user input to start applying changes
Plugins now work on Apple Silicon (M1) devices running Photoshop (or any other host program) both natively or through Rosetta
Updated AI engine
Added “Submit Feature Request” under the Help menu
Increased accuracy of auto-model detection
Fixes
Fixed processing status not showing when running in plugin mode
Fixed various JPEG loading issues
Fixed some EXIF data crashes on CR2 files
Fixed writing of fractional values in metadata for TIFF/DNG (Windows only)
Fixed inaccurate count with file saving panel
Fixed file saving panel staying open when opening an image
Fixed some color desaturation on DNG saves for some RAW types
Fixed Select All being left checked if you double clicked a checkbox quickly
Fixed long save paths overflowing the save dialog
Fixed crash when zooming in very close
Fixed pixelated preview issue
Fixed login password field not accepting spaces in middle of passwords
Fixed processing time overlapping controls when opening preview after saving
Changed some EXIF data so it trims ending spaces
Changed how external editor files are saved
Should no longer leave an 8kb file if the save fails
Minor Changes
Changed buy button so that it shows the login screen as well as opening the website
Changed spacing around the app name and version
Added login buttons to watermark prompts to hopefully reduce confusion when not signed in
Fixed some pixel shifting between the original and preview
Fixed errors related to installing plugins
Fixed errors opening Sharpen AI on Windows 7 machines
Fixed Find Objects button being removed
Um dos melhores softwares para o que se propõe, porém dependendo do assunto ele inventa umas texturas que ficam parecendo que a foto foi impressa em tecido canvas sabe?
Vocês também percebem isso?
Eu uso o Topaz Denoise pra fazer o sharpen. Não percebo especificamente essa textura, não, mas por vezes ele inventa umas coisas, sim. É o que dar querer tirar informação de onde não existe.
O esquema de usar o Topaz é duplicar a camada (ou criar uma camada estampa) no PS, ir em Filtro/Topaz… ajustar os parâmetros, aplicar e quando voltar para o PS vir mascarando.
No caso do Denoise, dependendo funciona bem é usar o Blend If, e ir retirando a aplicação nas altas luzes, deixando assim elas intactas e atingindo somente as sombras onde geralmente o ruído fica.
No caso so Sharpen em geral também gosto de tirar pelo Blend If uns 20-30% da luminância dos tons mais claros, pra tirar justamente algum halo que tenha se formado e que fica bem aparente. Acho que sharpen de highlight acaba ficando muito aparente (acima da zona 7, 8, 9, 10 de tons).
Além do Belnd if, sempre temos como usar ainda a máscara de camada no PS ou outro editor de fotos. Com isso vamos tirando seletivamente onde não queremos.
Mas enfim, às vezes é preciso fazer o tratamento em etapas, seja por conta da luminosidade, seja por conta do desfoque.
